Previous in Forum: What is Thermic Corrosion?   Next in Forum: What Spray Will Make Common Color Photos Archival?
removing Gold ball bond without destroying IC chip pad
04/27/2009 10:30 AM
Does anyone know how to remove Gold ball bonds from a semiconductor without destroying the integrity of the chip? I tried using a gold etchant that is cyanide based but it destroys the paladium and pits the aluminum and copper pads. any Ideas?
Good Answers: 38
Re: removing Gold ball bond without destroying IC chip pad
04/28/2009 12:01 AM
You need a solvent that disolves the bond material, not an etchant
check what bond material is used
http://www.ami.ac.uk/courses/topics/0203_dbm/index.html
04/28/2009 10:29 AM
thats really not my issue I need to eat away at the gold to leave some left on the pad to re ball bond to it. i dont want to shear it because it scrapes the die. I need to bring it down to about 20 microns and then reattach a new ball to the gold after I run it through some tests.
Good Answers: 38
04/28/2009 8:38 PM
You could try lasering it that is the only thing i can think of that is accurate enough and leaves the rest unharmed. I know it works on ITO tracks but have never tried it on a gold ball.
