Previous in Forum: Premium Freight   Next in Forum: What Is It: Rillenglas Offner
What's the maximum bearable thermal limit for hot surfaces for human fingers?
04/29/2009 10:58 AM
Dear Readers,
Subject: What's the maximum bearable thermal limit for hot surfaces for human fingers/body?
Does any body know the temperature limit for the external touchable hot surfaces of enclosure allowed by IEC60065 and IEC60950 standards for consumer electrical and electronics devices?
Any URLs or resources will be helpful.
Thanks
ψΩΦ
This discussion was "closed" on 04/30/2009 7:17 AM. No new comments are allowed.
Message from admins:
Stop posting the same question over and over.
Good Answers: 183
Re: What's the maximum bearable thermal limit for hot surfaces for human fingers?
04/29/2009 2:08 PM
The human body temperature is 37°C. The max bearable temperature depends on the conductivity of the hot body the hand/finger will touch. Under the skin the blood convects heat from the contact zone. If the transmitted heat is withi the convective limits of the blood circulation the skin temperature does not grow too high and the cells will not be "boiled". The higher the conductivity the lower has to be the hot body temperature. For metals it should stay around 40°C. The critical temperature for the cells destruction is over 50°C. Meat is grilled at 60°C.
The above mentionned convective capability connected to the low heat content of coal and its low conductivity as well as to the thicker skin of the foot allows the impressive walk on burning coal.
04/29/2009 5:25 PM
Hi Nick Name,
It is really appreciated very much, your explanations are logical. Would you please provide some URL/web links to read more about what you have stated?
Is there any standard regional or international that requires that external surfaces of the enclosures of consumer devices be kept below 40° C?
Thanks,
04/29/2009 8:36 PM
Personnel protection type barriers/insulation are usually specified in industry for surfaces over 70 degC that could be contacted accidentally.
Good Answers: 183
04/30/2009 6:08 AM
Sorry, those are informations obtained long time ago when I worked on a special project where there was a risk of contact with hot surfaces.
It should be considered that when the contact is very limited in time temperature can be over 40..50°C but the higher it is the higher the probability of tissues destruction.
Good Answers: 101
04/30/2009 3:39 AM
  1. Touch a surface with your bare fingers.
  2. Measure and record its temperature.
  3. Heat the surface up slowly.
  4. When you start howling, you know you've exceeded the tolerance limit. Note and record it down.
Disclaimer: this process definitely works. However, your company Safety Department could possibly disapprove of it .
Anonymous Poster (2); DVader1000 (1); nick name (2)
You might be interested in: Limit Switches, Hot Stamping Foils
