Previous in Forum: Dynamic Characteristic of AVR   Next in Forum: Protection Class CT's
AC motor nameplate markings vs Actual test
04/29/2009 11:48 AM
I have a 3hp, 400 VAC, 50 HZ, 3 ph, 1.15 SF motor with the nameplate Full Load Amps of 4.8.The namufacturer ran IEEE 112, Method B tests. Data at 100% of load indcates 5.2 amps. MG-1, 12.47, indicates that input amps can vary by 10% of nameplate value. How is the nameplate value determined and is the higher value a concern?
Re: AC motor nameplate markings vs Actual test
04/29/2009 3:25 PM
Your motor has a service factor of 1.15, which means that it can operate at up to 5.52 amps without damage.
04/29/2009 4:52 PM
When motor is running, it drives a fan. The current reading is 5.8 amps when air density is high. Does running at the higher amperage damage the motor?
04/29/2009 5:03 PM
That's hard to answer. It depends on the brand of motor and the actual amount of headroom designed into the windings. My gut reaction is it will shorten the life of the motor, but not by much. If it's been in service for some time and hasn't died yet, give it a go.
Not to plug a certain motor, but Baldors are better at tolerating some overloading than most others.
Good Answers: 804
04/29/2009 7:50 PM
The "official" definition of Service Factor is NEMA publications says something to the effect that SF is an amount of additional output power the motor can deliver for a short time (not defined), but at which other stated performance date will not be accurate. it also goes on to say that expected motor life will be diminished.
But those are guidelines, there is no hard and fast rule for what that 1.15SF really means, othr than the fact that if the motor is run in the SF, the amps will be higher. So every motor design will be different, but it's a given that you will increase the motor winding temperature. The one real rule is that for every 10 deg. C you raise the motor winding temperature above its rating, you cut the expected motor life in half. So if for instance your motor has a winding insulation temperature rating of 155C, and because you run it into the SF continuously, the windings get to 165C, you have shortened the motor life to 1/2 of what it should have been.
Anonymous Poster (1); JRaef (1); lyn (2)
You might be interested in: Label and Nameplate Services, Pushbutton Switches
