Previous in Forum: How to Select an SSR for Motor Switching   Next in Forum: Alternator Excitation Voltage
9 comments
Primary current
04/30/2009 5:06 AM
How to calculate the primary current of a step down transformer
Re: Primary current
04/30/2009 5:16 AM
Secondary power Ps = Is x Vs (Secondary current x secondary voltage)
Primary power Pp = Ps ÷ ε (Secondary power ÷ efficiency)
Primary current Ip = Pp ÷ Vp (Primary power ÷ primary voltage)
Just substitute in the known values.
Re: Primary current
04/30/2009 5:45 AM
How to know the effiiciency?
Re: Primary current
04/30/2009 5:52 AM
Ask the manufacturer. If you can't get anywhere that way, look at data for transformers of similar size & construction for which you can find the data, and take the average (or lowest, if you want to be on the safe side).
Re: Primary current
04/30/2009 7:16 AM
Hi,
If we know the turns of both the windings & the current in secondary, then it is much easier to calculate the current in primary.
Ip/Is = Ns/Np
Further the above eqn =>
Is =(Np/Ns) x Ip
Where
Np->Turns of primary Winding
Ns->Turns on secondary winding
Ip->Primary current
Is->Secondary current
Hari
[Information is knowledge]
Re: Primary current
04/30/2009 7:41 AM
But this is for an ideal transformer. It ignores losses (resistance in both windings + magnetic coupling losses).
Re: Primary current
05/01/2009 8:12 PM
What is your transformer KVA? (Power)
What is your transformer primary voltage?
What is your transformer secondary voltage?
You need all these information to do the primary current calculation.
Re: Primary current
05/02/2009 12:03 AM
I don't know the power (KVA), The primary voltage is 415V, Secondary Voltages are 24V 2.5Amps, 24.5V 5Amps, 220V 2.5Amps I know only these informations from my transformer.
Re: Primary current
05/02/2009 10:22 AM
Output: (24 x 2.5) + (24 x 5) + (220 * 2.5) = 60 + 120 + 550 = 730VA
Assume 80% efficiency, so input is ≈ 912VA. That gives input current ≈ 912/415 ≈ 2.2A.
Re: Primary current
05/03/2009 8:34 PM
MR. JohnDC has given you the answer to your problem.
Since you dont have the transformer KVA, you can calculate the transformer primary current from the secondary side of the transformer.
Secondary Output: (24(V) x 2.5(I)) + (24(V) x 5(I)) + (220(V) * 2.5(I)) = 60 + 120 + 550 = 730VA (Secondary output KVA)
Assume 80% efficiency, so input is ≈ 912VA. That gives input current ≈ 912/415 ≈ 2.2A. (Primary current = KVA/V)
Register to Reply 9 comments
haricool (1); JohnDG (4); rakheshrh (2); Simon Wan (2)
