Previous in Forum: Primary current   Next in Forum: Durant 6600 Programmable Sequence Controller
Alternator Excitation Voltage
04/30/2009 7:41 AM
hai friends,
how i calculate the excitation current required for a particular MW Generation.for Example 7.5 MW 492A, 11KV Alternator excitation voltage and current at full load is 150V and 4.4A. assume the PF is constant how i calculate the excitation current and voltage at 5MW.
Pl. guide me to find the calculation. thank you,
Good Answers: 137
Re: Alternator Excitation Voltage
05/01/2009 8:10 AM
Why would you want to calculate it? The voltage regulator should adjust the excitation voltage automatically to maintain the 11 kV output voltage.
But as power is proportional to magnetic field produced by the field coils, magnetisation is proportional to field current, and field current is proportional to field voltage (Ohm's law), I would expect field voltage to vary linearly with output power.
So in your case that's 100 volt.
Cheers..........Codey
05/02/2009 8:54 AM
Dear,
Assume pf = 0.8
Amps at 7.5 MW = 492 A, excitation is 150v, 4.4 A
Amp at 5 MW = 5000/1.732*11*0.8 = 328 Amp. with excitation of
Excitation voltage controls the reactive power. If your volts & PF are same,
KVA at 7.5 MW = 1.732 * 11kv * 492 = 9.373 KVA
KVA at 5 MW = 1.732 * 11* 328 = 6249 KVA.
excitation required at 5 MW = 6249*150/9373 = 100 V. @ 2.93 Amp.
Exploring the Science of Electricity
Register to Reply 2 comments
