Previous in Forum: Fire Sprinkler System   Next in Forum: Flange Thickness Calculation
Engine Wear Question
05/01/2009 3:36 AM
i have two gas fueled engines of the brand name waukesha and they are fully loaded 95% loading and i have noticed that the parts worn out before the manual says ,is that because of the conenious full load or might be because of the nature of the load ,it is a paper factory,using speed drived ,mills,dc motors and so much starting events.
Re: Engine Wear Question
05/03/2009 10:59 AM
It's not recommended to run your engine under full load 95% all time.
what you means by parts warn out before the manual says? Do you mean working life for engine or some other else
Reply to Forum Thread
