It has been requested of me to do some flow rate testing for a potential customer to properly size a pump for thier application. I have specific target "doseage" metrics to test to which is pretty straight forward. The problem is that they want to know what impact to the flow rate will be through varying lengths of distribution tube runs. Basically, you have the pump and controller in one room and it pumps out to another area anywhere between 25' and 200' thru either 1/4" or 3/8" poly tubing. This tubing is never run in a straight line with 90 degree turns and such, but rather has long sweeping curves throughout. Normally, you could calculate the pressure that is seen on the discharge of the pump, put a ball valve and gauge at the discharge and set to the desired backpressure and run some flow tests. Based on the length and curving of the tubing, calculating such a discharge pressure is difficult. What would you guys suggest as the best way to figure out the pressure that the discharge of the pump will see when run this way? Sorry if that doesn't make much sense, please ask questions to clarify. Thanks
