Guest should be informed that CR4 is not a place where people do your homework for you. However, we are not above pointing people in the right direction to get them started or asking questions back to get them thinking.
You have not provided enough information to point you in any specific direction other than suggest you google fm, "fm transmitter" or similar topics and start reading. There is a ton of information out there and some of it is country specific. You should find what you need to help with your particular report. I also assume that you received enough in class either in lecture or in your text to help get you started. You may even ask your professor if he/she can suggest a good source for you to start looking.
