I am presently trying to solve this problem at work. We have electric baseboard heaters (125 Watts/lin ft) in a hotel lobby with stainless steel grills that are approximately 10-12" above the floor. During operation of the heaters in winter the grills heat up to approximately 165 degrees F causing concern that someone may get burned if they touch them or melt plastic bags/purses ir set on them. Is there a material that the grills can be coated with that will reflect all or most of the heat given off from the electric elements thereby reducing the surface temperature of the stainless steel grills?
