Previous in Forum: Cable Sizing   Next in Forum: Reg. Free Wheeling Diode
installed power vs transformer rating
05/03/2009 3:22 AM
For one of the residential building the installed power is working out around 190 kw for all the units including for AC's.I appreciate if somebody can suggest suitable rating for the transformer to be installed and also how to take care of overloading.
Re: installed power vs transformer rating
05/03/2009 3:35 PM
Size the transformer for the intended load (including any estimated new loads due to expansion, etc), peak motor and compressor load, environmental de-rating (such as high ambient temperature, you could be in Dubai for all I know). Get a transformer that is of a higher rating than what you estimate you need. Protection of the transformer is primarily performed by the circuit breaker or fuse protection on the main transformer feeder and the branch feeders powering the different loads in the building.
You really should be getting someone qualified to do this for you, is this for a cost estimating or tender proposal?
05/03/2009 9:17 PM
Thank you for prompt response.This is for verification purpose as the order had been placed for 100 kva.
05/04/2009 2:55 AM
dear,
Following may justify ?
Application : Residential , i.e. un balanced load.
Installed load : 190 KW
Power factor for L&F with ACs : 0.55 average.
Load factor : normally 0.45 , night times, with AC , 0.65
Demand on transformer : Normal - 155 kva , Peak - 224 kva
We suggest after derating with ambient., 250 KVA transformer minimum
with 200% Neutral for internal winding of transformer.
( unbalanced currents that can flow in neutral shall be 1.732 * Ir max.
Exploring the Science of Electricity
Anonymous Poster (1); harry potter (1); jack of all trades (1)
