Previous in Forum: elliptical tank size   Next in Forum: Line pressure
MDMT
05/03/2009 5:07 AM
Minimum Design Metal Temperature means that up to that temparature we can use that metal or what? And again MDMT is at particular pressure or what ?
Good Answers: 51
Re: MDMT
05/03/2009 4:17 PM
Minimum Design Metal Temperature (MDMT) is the LOWEST temperature that the vessel may be operated at (in other words, you must operate the vessel at a temperature higher than MDMT). The MDMT marked on the nameplate shall correspond to a coincident pressure equal to the MAWP. When there are multiple MAWP's, the largest value shall be used to establish the MDMT marked on the nameplate, though additional MDMT's corresponding with other MAWP's may also be marked on the nameplate.
A little knowledge is a dangerous thing.
Reply to Forum Thread
