Previous in Forum: Mositure Control   Next in Forum: Earth Grounding
Identifying Chemical Leaks
11/22/2006 6:47 AM
hi,
in our company,hazardous chemicals are using,chemical detector also there for finding chemical leak,but inside the m\c,many small chemical pipe are there.all tupe are white color,it very diffcut to find leak point .my ques is-is there any special type of tupe,if there is any leak ,the tupe outside color should be changed in that leaking point,we can identify the leak and leak point.
Pathfinder Tags: chemical
Re: Identifying Chemical Leaks
11/23/2006 2:36 AM
Depending on what is leaking, a variable wavelength light source or a themal imaging unit could help visualize a leak.
11/23/2006 4:32 PM
hi,pl explain more,i want such a system to detect leak,pl help me
Good Answers: 54
11/23/2006 3:41 AM
'Took me awhile to get what you're asking.
What you're looking for is a kind of paint that changes color if a certain chemical comes into contact with it? I don't really know of such a paint but we use a device to detect leaks. It "hears" the ultrasonic sound generated by leaking pipes. Check out their website www.uesystems.com.
11/23/2006 3:35 PM
There are spray on systems (aerosol cans) you can get as a 3x spray paint coatings
These will show up any cracks etc once the chemical has set.
11/23/2006 4:31 PM
hi.pl explain more,i want such a paint to detect leak.pl help me
Anonymous Poster (2); paramasivan4u (2); Vulcan (1)
