Previous in Forum: Handheld Moisture Tester for Wood   Next in Forum: pH and ORP Sensors and Electrode
Software Signal to Hardware Signal
11/22/2006 6:54 AM
hi,
how we can convert software data signal to hardware signal like on and off,pls explain.
Re: Software Signal to Hardware Signal
11/22/2006 8:55 AM
Hi, paramsivan4u. Can you provide the forum with some more information? For example, what are the details of the software and hardware configuration that you plan to use?
11/22/2006 6:51 PM
hi,already m\c screen has the display output,.i want to take the output as a harware output like open and close by converting the software to digital output.
11/22/2006 10:20 AM
Generally speaking, the idea is to get the software to toggle a pin on the processor chip - that's your hardware signal. Most processors have i/o pins that can be controlled by s/w.
11/22/2006 6:47 PM
thank you for your information.
11/23/2006 12:24 PM
It depends on what platform you are working. If that is microcontroller programming it requires to know the i/o ports provided and the corresponding address.
If it is on a PC the parallel port is the best solution. Its address is 378H. so a code like
out 378H 8 ;
will turn on the 4th bit ON (because 4=00001000 in binary)
Good work
GetachewT
Anonymous Poster (2); bhankiii (1); paramasivan4u (2)
