Previous in Forum: ISA Standards and Recommended Practices for Instrumentation and Control   Next in Forum: Motor Operated Valves and Flow Control Valves
8 comments
Frequency of Gas Leaks
05/05/2009 5:38 AM
Can anyone give me the formula to calculate the frequency of the sound produced for a known pressure of gas leaking through a known size orifice
Pathfinder Tags: gas leak
Re: frequency of a gas leak
05/05/2009 5:39 AM
It will be white noise.
05/05/2009 6:02 AM
The reason for this question is as follows.
I need to build a test rig for an sonic leak detector, these detectors respond to a frequency of 20kHz to 25KHz. although any leak is as you say white noise there are main fundamental frequency's that predominate.
05/06/2009 1:25 AM
The predominant frequencies will, I believe, be mainly determined by the size and shape of the orifice through which the leak occurs. The pitch of a wind instrument changes only a little over a significant range of pressures, but more rapidly with changes in the dimensions. Think of your leak as a tiny whistle.Tiny does imply very high frequency (which is why it takes a pretty big leak for me to hear it...).
Good Answers: 101
05/05/2009 6:48 AM
Or it may be EVP .......
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: Frequency of Gas Leaks
05/06/2009 1:21 AM
I use an ultraphonic device to measure leaks in a valve and i set it at 40
sensitivity of the same needs to be adjusted for different applications though,
but 40 k works.
25k may not be the right freq for leaks,
Regards
Naveen
05/06/2009 5:36 AM
The pump size and speed and the shape and the size of the orifice are ?
05/06/2009 3:53 PM
Peter-H
I believe you should be looking for decibels ,dB, rather than frequency.
Air escaping through an orifice from a source exceeding approx. 13 psig will be at sonic velocity. A big hole will make more noise than a small hole but the frequency will be approximately the same. Also sound, dB's, attenuate with the square of the distance from source to measurement.
If I whisper "hello" or shout "HELLO" the frequency will be similar. The difference in noise will be the higher decibels of the shout. Should I chance to sing "h-e-l-l-o" in high falsetto or bombastic baritone the frequency may be slightly different but the ability to detect will still be volume or decibels.
Sound (pun intended) plausible? Tom
05/07/2009 1:33 AM
I think you could use the ISA standard on the noise detection formula of control valves
ISA-75.17 1989.
Register to Reply 8 comments
dadw5boys (1); dkwarner (1); DVader1000 (1); naveen_menon (2); peter-h (1); PWSlack (1); Tom Kreher (1)
