Previous in Forum: Selection of Transformer Vector Group   Next in Forum: Motor Rewind Question
Efficiency of a Hybrid System
05/05/2009 9:39 AM
Hi All,
I'm currently building a a hybrid system that contains a solar panel, an adjustable voltage regulator, Reversible Fuel Cell, DC-DC converter and and a DC-AC converter.
The output of the solar panel is (17.82 V, 0.57 A, 10W)
which I have connected to an adjustable voltage regulator
(3 to 30V input voltage, Up to 10W output power, 1A continuous output current, Efficiency up to 92%, output voltage 1.25 V to 13 V)
so that I can take 2V and 1A to power the reversible fuel cell (in electrolysis mode) to produce hydrogen and oxygen). I have found that the reversible fuel cell is about 35% efficient.
I would like to calculate the efficiency of the system so far.
Please suggest.
Gyandeep
PS- may you please suggest how the voltage regulator and dc-dc converters work? if the input is 17.82 V and 0.57 A, and the output we take is 2 V and 1A, how do we calculate the efficiency?
Re: Efficiency of a Hybrid System
05/05/2009 10:34 AM
input power = 17.82 X 0.57 = 10.16 Watts
output power = 2 X 1 = 2 Watts
efficiency just less than 20%
Good Answers: 73
05/05/2009 12:20 PM
On your question about DC-DC converters, the source power (DC input) has to be converted to AC where it can be transformed to an appropriate level and then converted back to DC at the desired level.
The product of Volts and Amps yields Watts. Efficiency is always Output divided by Input. Note that you can never get more out than you put in. So, it is impossible for the output to exceed the input. Continuous output current requires continuous input power within the specifications. The solar panel is most likely old technology which is subject to rapid reduction of power output if shaded or under cloudy conditions.
A human in good health can generate about 40 Watts of continuous power. So, at 10 Watts you be going anywhere very fast.
