Previous in Forum: Formula One Engines   Next in Forum: 1991 Nissan Maxima - Battery Light Goes On and Off
8 comments
2002 GMC Sierra - Steering Problem
05/06/2009 1:21 PM
I have a 2002 GMC 1500 sierra 4x4 ex cab PU with a 5.4L engine. Something is wrong with the steering, it turns to the left just fine but takes both hands and all your strength to turn right (at low speed) even with high engine rpm. This tells me that the pump is fine and the problem is in the steering valve.
What is wrong? Is this common?
Thanks!
OT
Cliff
Re: 2002 GMC Sierra - Steering Problem
05/06/2009 2:48 PM
I too would guess it is the valve.
Good Answers: 101
05/06/2009 3:59 PM
ditto
05/06/2009 11:46 PM
Yes the steering box, which is a manually assisted servo acuator. The simple solution is to replace the unit complete and be done with it. Repairs are difficult on these units as they very seldom fail. I have seen one or two that broke the servo shaft and went "hard over". Luckily know one that I was involved with this was injured, but....
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
05/07/2009 9:47 AM
Correct, I have a 2004. Same problem and it was indeed the steering box.
05/07/2009 7:09 AM
I believe GM was using rack n pinions by 2002 in pickups and the trouble you describe is common for a "rack". It is also possible but less common in the old style steering box.
Good Answers: 101
05/07/2009 11:16 AM
And a Hello From up the street Oregon Tinker. You in Eugene?
01/11/2011 6:45 PM
I have exactly the same problem with my 2002 GMC Sierra. Did it turn out to be only the gear box or did you have to also replace the rack and pinion also?
01/12/2011 1:47 PM
Thanks for the replies folks, that incident was about a year ago. I bought a seal kit for around $62, removed the battery, some wiring and hoses, made an access tunnel using bungee cords to hold stuff back and did open steering box surgury on it! It was very difficult but it worked. One of the seals had smeared off between the left turn and tank passages. The seals used to seperate pressure, return to tank, left and right oil passages are made of a green cardboard like substance and they don't like to stretch. I was able to lubricate the spool and the seals with tranny fluid and roll them into the grooves using an o-ring removal pick set. The fiberous seals had stretched and didn't want to duck fully into the grooves which took many minutes of working the housing back into place. The job took four hours but has worked well for the last 15,000 miles or so.
OT
Cliff
Register to Reply 8 comments
Anonymous Poster (3); MIKE L. (1); millerwm2002 (1); Oregon Tinker (1); RVZ717 (2)
