Previous in Forum: Leak Detection Methods in a Water Pipeline   Next in Forum: Pro/Engineer
Centrifugal Fan Operating Point on Performance Curve
05/06/2009 2:46 PM
I have a centrifugal fan along with its performance curve and the curve has design point where it is supposed to work at a specific flow and specific BHP .But this is design data, how can I find the actual working point of this fan on the performance curve. This fan is in operation what and how should I measure any specific parameter in order to find the current working point of this fan.
Appreciate the help of the folks
Thanks
Jack
Re: Centrifugal Fan Operating Point on Performance Curve
05/06/2009 4:22 PM
Drill a small hole (holes) in the discharge ducting near the fan and get pressure (pitot) measurements (may want to get someone experienced with gridding/averaging) - you will then have the exact operating point on the curve.
05/06/2009 5:33 PM
If you have the performance curve, measure the motor load in your application and lay it on the curve. Should be relatively simple. Amps vs output.
Good Answers: 58
05/06/2009 10:01 PM
A combination of reply 1 and lynlynch in reply 2 is best. One measurement will verify the other (within the accuracy limits of the measurement).
Anonymous Poster (1); lyn (1); The Prof (1)
