Previous in Forum: Motor Operated Valves and Flow Control Valves   Next in Forum: SIL Certification for Metering Systems
How to Earth a Gas Wellhead Monitoring System
05/06/2009 11:01 PM
Hi every body,
well we have justed finished our SCADA installation which comprises of Honeywell PTs, Kobold TT, AB RTU, and sollatec Solar panel. It's basically a gas well head monitering systemand we have got an issue regarding the Pipe line mounted instruments i.e. PTand TT grounding.will you please help me out, as how that can be accomplished? thanks
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: Instrumentation earthing
05/07/2009 1:40 AM
Hi
Could you please explain as to what is the issue with the grounding ?
Pipieline mounted inst, is the pressure transmitter mounted directly on the pipeline??
If you want to have a saperate ground system apart from your electrical ground, Dig saperate pits and use these, Use any config as you like.
Regards
Naveen
Reply to Forum Thread
