Previous in Forum: How to Earth a Gas Wellhead Monitoring System   Next in Forum: Oscilloscopes
SIL Certification for Metering Systems
05/07/2009 2:20 AM
Hi all, I've to prepare the technical clarification concerning SIL requirement on two kind of custody metering system which stated that the USM for gas custody meter and turbine meter for liquid custody meter. Are they both meters to be complying with SIL? Or the turbine meter only. Understood there were two categories been defined by IE 61508 such "hardware safety integrity and systematic safety integrity". It would be appreciated for someone to assist.
Re: SIL application
05/07/2009 8:40 AM
Does SIL stand for Safety Integrity Level?
Re: SIL application
05/08/2009 2:48 AM
Yes it is. And should the gas/liquid custody meters system complies with SIL (either using "Ultrasonic Meter (USM) or Turbine"?
Re: SIL Certification for Metering Systems
05/09/2009 4:15 PM
hi,
SIL Value will be defined duiring PHA/Hazop analysis, depending upon the frequency/consequence/Proability of the loop.
Having said if SIL Is not defined for this particular loop during HAZOP,no need to go for SIL certified sysytem,
Morever your scheme will be somewat like dis for custody (From inlet-to meter- FCV -motorised actuator -prover sysytem-finally outlet) so here the question of Safety shut off valve doesnt come into the picture /OR Equipment under control doesnt come, so we can safely say SIL certification is not required
Emphasis should be made to have amore accurate reading since its used for custody metering
Regards
Jose John
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
05/20/2009 5:07 PM
try this gives how to go for sil
http://www.iceweb.com.au/sis/target_sis.htm
Register to Reply 4 comments
Anonymous Poster (1); find2am (1); josej (1); Ynnor (1)
