Previous in Forum: SIL Certification for Metering Systems   Next in Forum: How to Charge a Wavetek CT233 Probe
11 comments
Oscilloscopes
05/07/2009 2:57 PM
hi
please i want to ask about the oscilloscope in the workbench
how it work ?
how can we connect it with the clt?
how can we get the Vo signal?
thanks alot
Re: Oscilloscopes
05/07/2009 7:00 PM
Take a picture of the "knob" side of your scope and send it to us.
Re: Oscilloscopes
05/07/2009 10:52 PM
Saif,
You will need to plug it into the hole in the wall where the electricity comes out and press the big button on the front marked "ON".
Chris
Re: Oscilloscopes
05/11/2009 12:30 PM
thank you so much
now ican use it very well
Re: Oscilloscopes
05/08/2009 3:01 AM
If all else fails, read the instructions.
Location: Currently on break at home in Houston, Texas USA
Re: Oscilloscopes
05/08/2009 5:50 AM
Follow this URL to an oscilloscope primer by Tektronix. It should get you up and running in no time. http://www.tek.com/Measurement/App_Notes/XYZs/03W_8605_3.pdf
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
Re: Oscilloscopes
05/08/2009 4:19 PM
Nice avitar! Is that Ready Kilowatt? Or does Houston have different name for him?
David A Goodman
Re: Oscilloscopes
05/08/2009 6:07 AM
Does this help? :-
http://vlsilab.fiu.edu/projects/Electronic_Work_Bench_Tutorial/Work_Bench.pdf
Trouble is workbench (and to a lesser extent oscilloscope) is a very common word in the English language, so, I think your question has not been understood.
Re: Oscilloscopes
05/08/2009 6:24 AM
GA Randell and you're right - this was misunderstood by myself.
Re: Oscilloscopes
05/11/2009 6:29 PM
thank you
realy this websit help me very well
Re: Oscilloscopes
05/08/2009 11:17 AM
Hi, and welcome to CR4.
You will need to give more information about what you are doing. What is a clt? Where is the Vo signal coming from, etc. An oscilloscope basically draws a graph with voltage vertically and time horizontally.
regards,
-S
Re: Oscilloscopes
05/08/2009 4:21 PM
I use a freeware o-scope program in my classroom. It uses the audio card and inputs and works great for just about everything you could imagine. It also has a good tutorial. I forgot where I got it, but Google "freeware oscilloscope."
David A Goodman
Register to Reply 11 comments
Anonymous Poster (1); DAG (2); fatma saif (2); lyn (1); PWSlack (1); Randall (1); StandardsGuy (1); tropicalspeed (2)
You might be interested in: Signal Conditioner Chips, Signal Isolators
