Previous in Forum: Increasing Transformer Capacity   Next in Forum: CBCT selection calculation
Noisy UPS in Kenya
05/07/2009 3:38 AM
we are having problem with connection of ups and ct-scan machine and input powerwe had a loud sound from our 100kva ups .what might be problem? clue the ups was on with row power and when it made that loud sound, then the power of the town went off.does these ups returns the power back. the make of ups is gamatronics 100kva with 10kva models each. regards to all chris from kenya.
Good Answers: 54
Re: we are having problem with connection of ups and ct-scan machine and input power
05/07/2009 7:28 AM
What kind of loud sound? If it was a bang, your UPS is probably dead and needs to be taken out for servicing or replacement.
If it's a loud buzzing or humming noise, it could be a transformer that's going bad. You still need to have it taken out for servicing or replacement.
Whatever it is, I suggest you contact the supplier or Gamatronics directly and have them take a look.
regards,
Vulcan
Location: Currently on break at home in Houston, Texas USA
Re: Noisy UPS in Kenya
05/08/2009 5:41 AM
The output side of a UPS consists of an inverter feeding a transformer. If the inverter bridge is triggering improperly, it will create a noise in the output transformer and require servicing.
The input side of a UPS consists of a rectifier bridge. A defective bridge will creaie a noise and would require servicing. In any case, if the UPS is generating noises, it will require servicing.
05/08/2009 8:26 AM
Some UPS's use switching power supplies to rectify in incoming AC power whereby introducing switching harmonics to the incoming power connection. If the town's power source has a relatively small capacity (say 100 kW feeding your 100kva UPS), it is possible that your large UPS is back feeding noise (harmonics) to this source. The source may have an intolerance to these harmonics.
szwasta (1); tropicalspeed (1); Vulcan (1)
