Previous in Forum: Shielded Medium Voltage Cables   Next in Forum: straightness opreation of try square
Fabrication and Welding of Plastics
05/07/2009 8:05 PM
Hey gurus, I have been asked to provide services for welding and repair of tanks in some industrial settings (galvanizing, pickling, etc.).
I am pretty good at the hot air or gas method and even taught it in an apprenticeship program many years ago.
Estimating for fabrication and fitting is a snap for me, but estimating weld times and cost are not my forte.
Does anyone know any links, books, hints, etc for the welding of PP with the hot air/gas method?
Here in the tri state area I find the companies doing it years ago have all closed or diversified and not doing it anymore as they got larger.
The ones who are still in business have taken the route of cleaner work.
Thanks in advance.
Re: Fabrication and Welding of Plastics
05/07/2009 10:37 PM
I worked for a company that did this. Welded PP. Get a welder and run some beads.
Use different feed rates and heats and figure it out. It's not rocket science.
It's different than PVC, but not too much.
If all else fails, go to someone who makes PCB fab equipment.
06/16/2009 3:57 AM
We are the fabricators and making PP tanks for PCB & GRAVURE Rollers. The maximum size we had made is 3800mm long X 2500mm wide X 1500mm Hight out of 25mm thick PP plate. If U can send the detail specs of the job then We might give you comments.
Reply me on aarchy_ind@hotmail.com
Thanks
A H Shah
Register to Reply 2 comments
