Previous in Forum: Fabrication and Welding of Plastics   Next in Forum: straight the triangular file
straightness opreation of try square
05/08/2009 12:53 AM
how to staight the try square by automatic feeding the rod into the machine of 5m with the accuracy of 0.1 mm.
Re: straightness opreation of try square
05/08/2009 3:06 AM
<...how to staight the try square...>
Try-squares can be assessed for straightness by drawing a line at 90deg to a flat edge, flipping the square over, and drawing another line. If the two lines are parallel, then the square is true.
If it is out-of-true, then the best thing to do is to replace it.
The remainder of the question is abstruse.
05/11/2009 3:58 AM
Answers to the same question raised the other day might indicate that there is insufficient information in the question for forum subscribers to understand it properly.
Register to Reply 2 comments
