Previous in Forum: Roll of production planing and control   Next in Forum: gantry crane material
Conversion of pressure into energy equation
05/08/2009 2:29 PM
I am trying to convert the pressure N/m^2 into energy Nm.
A pressurized water in a cylinder has a pressure of 10 kn/m^2, and the volume of the water is 1 m^3.
To find the stored energy, I multiply 10 kn/m^2 X 1m^3 = 10 knm of stored energy. Is this the correct conversion. If not , can any engineer help me to do the right conversion. Thanks.
Good Answers: 143
Re: Conversion of pressure into energy equation
05/08/2009 4:03 PM
It has very little energy. The approximate formula is
E = 0.5λVoP2
where λ is the compressibility of water (≈4.3 x 10-10 m2/N), Vo is the volume before pressurization (we aren't told that, but can just use 1 m3, and p is the pressure. I'll probably now screw up the units, so check with somebody who has at least a two digit IQ (). Anyway, I get 0.02 J. That seems too low - I would have guessed at least 10J - so I probably screwed up the compressibility. HELP!
05/08/2009 5:35 PM
"pressurized water in a cylinder has a pressure of 10 kn/m^2"
Are you sure?
http://www.engineeringtoolbox.com/pressure-units-converter-d_569.html
10,000 pascals = 1.450377 psi
The energy that might be contained in your cubic metre hardly seems bothering with!
Good Answers: 143
05/08/2009 5:51 PM
I'm still not sure about my units, but I worked it another way - how much work to compress it and got 0.05J, so maybe the 0.02J was OK.
05/11/2009 3:50 AM
The whole idea of doing hydraulic testing for pressure vessels is that the stored energy is very low and, should the vessel rupture during tests, the damage will be negligible.
Good Answers: 183
05/11/2009 1:11 PM
Since water is very "stiff" it should be better to consider as well the energy in the vessel (cylinder) deformation under pressure, it can be higher!
nick name (1); PWSlack (1); TVP45 (2); woodygb (1)
