Previous in Forum: Parallel operation with STATE GRID   Next in Forum: Cable lugs specifications
Grid parallel
05/09/2009 5:00 AM
When I put DG in grid parallel option, initially DG cannot take load, until I adjust the motorized POT. Why Dg cannot take load initially?? What is the reason?
Re: Grid parallel
05/09/2009 1:19 PM
please specify about your load,name of the synchronizing controller and DG rating. load sharing depends on the pre set parameter on your controller. when generator sychronizied with grid, controller give commands to (avr and governor ) slowly take over the loads depend on the percentage which you set on your controller.
Re: Grid parallel
05/10/2009 10:16 AM
Thanks for your reply!
1400Kw,SCGC controller.
I m adjusting manually by pot. what type of commend to give controller?what happen in alternator side at time of commend?
kindly tell me or send any soft copy in online?? pls
Re: Grid parallel
05/10/2009 12:24 PM
check your pot weather that is motorized or not. if motorized check, that is working properly or not. parameter setting for load sharing you have to call the panel supplier or technician from controller supplier. i have not idea about your controller. can you send me the manual for controller which you have mentioned.
Register to Reply 3 comments
