Previous in Forum: Camshaft Failure   Next in Forum: Robotic Pick and Place Machine - Malfunctioning Air Cyclinders
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
Vortex Breaker for LPG SPherical Tank
05/10/2009 11:17 AM
Dear all..
Continuing my previous question about Excess Flow Valve before..
Today, i want to ask you again about Vortex Breaker in LPG Spherical Tank.
Is it common to install vortex breaker in LPG spherical tank?
In what opening should i install that vortex breaker? LPG outlet nozzle and drain nozzle only or..??
For your info, the LPG is stored in liquid form (design pressure: 18 kg/cm2, design temperature: 50 C).
Ok, thanks all..
Please give respectful & positive answer than insulting! Respect each other ok..
Good Answers: 61
Re: Vortex Breaker for LPG SPherical Tank
05/10/2009 1:43 PM
"Is it common to install vortex breaker in LPG spherical tank?"
Yes!
Vortex breakers should be installed on the pump suction nozzle on most all tank and vessel types. This includes the standard flat botton, floating roof, API tank such as is used for the storage of crude oil, hydrocarbon products, water, etc..
Do it once and do it right
05/10/2009 9:26 PM
Ok Sir..
Thanks..
05/11/2009 4:02 AM
They are sometimes installed on water tanks as well.
Register to Reply 3 comments
PennPiper (1); Premium (1); PWSlack (1)
