Previous in Forum: Motorcyle Speedometers and Magnetic Fields   Next in Forum: Audi A4 or A6 (or Hella) - Accelerator Pedal Pinout
12 comments
Mercedes-Benz Bionic Car
05/10/2009 9:40 PM
I found this article about the Mercedes 'Bionic', a car they are developing based on the shape of fish to improve aerodynamic drag:
"When Mercedes-Benz began to contemplate its next generation of high-efficiency small cars, it sought aquatic inspiration. But instead of considering obvious undersea hot rods like sharks, the Mercedes team turned to a fish that resembled a car: the tropical boxfish. A native of the Indo-Pacific region, the Ostracion cubicus is surprisingly slick. Wind-tunnel testing of a clay model revealed a drag coefficient (Cd) of just 0.06, startlingly close to the ideal 0.04 of a water droplet."
So, I was wondering if there has been any research in applying the same principles to semi-trucks, like maybe a whale shaped truck, or a water droplet shaped front end? How much fuel would this save in a year?
Mercedes Bionic
Juggling Beatles
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
Re: Mercedes-Benz Bionic Car
05/11/2009 11:10 PM
I wonder if they are going to use the same inefficient hundred year old reciprocating piston engine as a power source? Probably so. They have too much invested.
Regards Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
Good Answers: 54
05/11/2009 11:40 PM
Yes, they have too much invested, but remember that Engineering is about real world solutions to real problems.
The existing I.C. engine technology is well understood, efficient, cheap to manufacture, scales well, has a high power to weight (or volume ratio), is responsive, is available instantly at start up, uses existing infrastructure (fuels, repairers, parts), is safe and is known to be reliable.
What're the realistic alternatives?
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 11
05/13/2009 9:06 PM
Dear ffei, An alternative is the Tesla Style turbine engine. It too is efficient (at least 85%), roughly one third the cost to manufacture (any competent machine shop), will use ANY fuel that can be introduced under pressure and ignited, higher pound-per-weight ratio the any other internal combustion engine in use today (at least 5 to 1), needs almost no maintenance (usually nothing more than a good cleaning with soap and water),safe and a version of these turbines (as water turbines) powered the electrical station at Niagara Falls for nearly 40 years with almost no maintenance.
Regards Dragon
P.S. My son and I are designing for manufacture a multi-staged design based on these turbines that will produce 600 h.p. and 1000 lbs/ft. torque. It's dimensions at this stage are 2'X2'X3'.
05/12/2009 12:30 AM
Nah, I heard they were going to use sails.
Good Answers: 74
05/12/2009 4:44 AM
I thought they were bionic already in some way.
Well, maybe not.
The Twain Has Met
05/12/2009 9:37 AM
LMAO Where did you find that picture?
Good Answers: 74
05/12/2009 4:59 PM
Mechanics are only good for 2 things. One is swinging the spanner....
The Twain Has Met
Canada - Member - BC Born, Alberta Raised, Quebec (poutine) crazed... Engineering Fields - Aerospace Engineering - An airplane is just a bunch of beams... Hobbies - Model Rocketry - Had fun as a kid...fun stuff Hobbies - CNC - dreaming of cutting Engineering Fields - Control Engineering - PID ME!
05/12/2009 9:54 AM
that's hilarious...
kkjensen
05/12/2009 2:53 PM
I once owned and even sold Citroens. The DS cars were shaped like truncated tear drops ( if you looked down on them ) wider in the front and narrower in the rear. These cars had been designed in wind tunnels and had a very low drag rate. Also the Citroen CX cars also had lsow drag rates.
05/13/2009 3:15 AM
Your idea would be much more feasible with trains...and, like the Mercedes concept relative to earlier car streamlining "fads," not much of a departure from train streamlining of the past. The problem with combination transports (semi-trailer and tractor truck combinations), is that the fish do not need to articulate behind their head as a big rig must. With bobtails, though, maybe there's a possibility, if cargo space is not negatively affected too much; but, of course headwind is not so much a factor for those truck types as it is for OTR rigs.
05/14/2009 9:59 AM
You make some very good points. I live right off I-80, and the amount of trucks rumbling by is endless. And, right out front of most of them is a great big flat plate where the radiator sits. Not the most streamlined shape. I wonder if it would be possible to calculate how much fuel would be saved per year if you put a whale-shaped shell over the front end of a Kenworth. On a more practical note, the trailer section seems to offer some opportunities to reduce drag that would at least be worth making a token effort to see if some simple ideas might improve fuel milage. The best way to achieve laminar flow is to use a flat, straight surface, which is exactly what a trailer is. However, the sides and top are cluttered with aerodynamic obstacles. These are necessary for strength of course, but what would happen if you blew some styrofoam, like they use on the Space Shuttle, over the entire outside of the trailer and then went back and flattened out the styrofoam so the entire outside of the trailer was completely flat and smooth? Laminar flow? And how about a train with all the cars completely flat from the engine to the caboose? Better fuel milage?
Cabover design
Good Answers: 74
05/13/2009 10:23 PM
Hi route89
I just found the time to watch that juggling Beatles. What a dedicated man! I can only hope that the future shapes of cars are as impressive. Thank you for that link, Ky.
The Twain Has Met
Register to Reply 12 comments
Anonymous Poster (2); Dragonsfarm (2); ffej (1); kkjensen (1); ky (3); livagain1 (1); redfred (1); route89 (1)
