Previous in Forum: AC to DC Conversion and Long Distance Power Transmission   Next in Forum: AC Motors - Changing 415V/50Hz to 400V/60Hz
Bus Bar Gutters
05/10/2009 11:09 PM
I am brad a young engineer from philippines, can someone give me an advice in busbar gutters ... i am confused since most of our busbar gutters has an enclosure grounding, but there are no devices just busses, can someone tell me what it is for since there are no devices inside it.
Re: Bus Bar Gutters
05/12/2009 12:32 AM
How about a photo?
Good Answers: 39
Re: Bus Bar Gutters
05/12/2009 9:00 AM
Metallic enclosures are normally grounded as part of the safety system. If something comes loose and touches the enclosure, this creates a grounded connection which will then trip the fault protection system. In simple terms this prevents an enclosure from being energized. It is intended to protect people from making contact with the energized busses contained inside. If vibration or criters like a mouse does create a conductive path to the grounded shell, the circuit breaker trips.
Depending on what voltage is involved the protective method may be simple or complex. In one power station I worked at, we had 27,600 volts AC inside the buss enclosures. The protective relaying was complex and expensive. In a typical factory with 440V AC bus bars , protection is just a breaker.
Elnav
Re: Bus Bar Gutters
05/12/2009 1:06 PM
tnx for the info sir :), since most of our bus gutters are ranging from 230~ upto 400~
so to provide safety we will place a grounding terminal for the enclosures.
Re: Bus Bar Gutters
05/12/2009 1:29 PM
The purpose of grounding and bonding is electrical safety. A low impedance path to ground will facilitate the operation of the overcurrent device rendering a short circuit harmless.
Re: Bus Bar Gutters
02/22/2011 3:32 PM
for submeters. some are use to contain cb( cb gutters)
