Previous in Forum: Specifications for Brite Steel   Next in Forum: DMC and UPVC Pipes
Carbon Steel Tanks and Caustic Soda
05/11/2009 3:44 AM
We have Carbon Steel Tank (150 m3) coated with 300micron of Phenolic Epoxy Paint (interline 850) currently used for storage of 25% Caustic Soda.
Can we use same tank for 49% Caustic Soda without any changes?
Re: Suitability of tank for 49% Caustic Soda
05/11/2009 4:02 AM
What temperature will you have the 49% at?
What condition is the tank in?
What was the tank designed for? Because 49% caustic is about 25% denser than 25% caustic.
Have you specifically asked the supplier/application engineer?
05/11/2009 4:33 AM
Depending on temperature, chemically, probably yes.
Given the greater density, the structure of the tank and its support require attention before any yes or no answer can be given.
Re: Carbon Steel Tanks and Caustic Soda
05/15/2009 8:06 PM
Depends in the time of residence , I mean how many hour and under what conditions the CAUSTIC SODA has been stored. If your plant is a big one, go and consult your safety engineer. You can consult also an ASME consultant.
If you have more questions, your safety engineer can ask somebody else like OSHA or a third party lab.
PROCESS:
You can performance some simulation on CHEMCAD (third party company) or in COMSOL software to simulate and predict some leaks or some mechanical failures in welding is so important to know the limits and charges (hydraulic charge), stresses and if the tank is always static or dynamic. If tank has LEGS you have to calculate some stress and limits on service time MAY BE you have to performance SOME UT or RT on T welding joints, valves , flanges and blind flanges and tubings.
ECONOMY AND COMMERCIAL:
If your plan is to put CAUSTIC SODA for a long time, you should study the option of build a new one, why? because of the ROI.
If wanna know more about fabrication let me know.
Israel Barron
ibarron@sfmex.com
www.sfmex.com
RT = X-RAYS TEST
UT = ULTRASONIC TEST
ROI = RETURN ON INVESTMENT
Israel Barron ibarron@sfmex.com
Anonymous Poster (1); Israel (1); PWSlack (1)
