Previous in Forum: Physics   Next in Forum: Calculating line loss for natural gas
Impeller inserted at water pipe line
05/12/2009 10:01 AM
Hi everybody! hope to help me with my imagination on how and where can i find an impeller that can be place along a water pipe line that is coming from a over head water tank and to bring back the water back to over head tank again to cycle. My other question is the impeller will have to drive a mechanical gear box that will drive a water pump.
Thank you,
Dela Pena
Re: Impeller inserted at water pipe line
05/12/2009 10:06 AM
Any pump that will overcome the head difference between the top level of the water and the top level of the inlet pipe, at the required circulating flowrate, will do.
The power input required is of the order of the [head difference] times the [volumetric flowrate] divided by, say 0.8, all expressed in compatible units.
Meanwhile, this might make interesting reading......
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
05/12/2009 10:15 AM
It almost sounds like you wish to build a perpetual motion machine. The only way you can pump the water back up is with an external power supply. Your machine cannot run all by itself. Do check out PW's link!
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 12
05/12/2009 3:41 PM
practically you can't do execute your idea because of mechanical losses for turbine, gearbox and pump in additional to friction losses results of water flow in pipes while you can install only water pump with a small power rate to overcome friction losses in pipes . With few calculations you can select power rate of your pump.
consider total pipes length for feeding pipe lines = L1 with diameter d1
pipe length for return line L2 with diameter d2
flow rate according to your choice = Q
Friction losses in pipes = ( f * L1 * Q2 ) / 3(d1)5 + ( f * L2 * Q2 ) / 3(d2)5 ---------(1)
where f is friction coefficient
now consider head different between feeding and return pipes around 0.5 bar approximately 5 meters water heat -------(2)
total pump head Ht = (1) + (2)
pump HP = µ * Q * Ht / 75 ξ
where µ water density 1000 Kg/M3 , Q in M3 / sec
Ht , d and L in meters
ξ pump efficiency
don't tell me who are you , what do you know is enough.
Bricktop (1); khairy Aish (1); PWSlack (1)
