Previous in Forum: slogan   Next in Forum: swivel ball joint for radio control servos or smaller
19 comments
Carbon Steel Mild Steel cracks.
05/12/2009 10:32 AM
We are providing NDT training in South Africa. We have a lot of welded samples we bought for the students as part of their training and practical examination. This is getting a little boring so we decided to make some samples ourselves.
We use mostly Carbon Steel \ Mild Steel for this exercise. We have access to MMAW and MIG\MAG welding. Believe it or not we are trying to get the plate and the welds to crack. Strange enough but when you want cracks, you get good welds. The plates we have heated up to almost melting point, putting them in ice water and guess what…no cracks.
Can anyone please assist me with some "tricks" on how to get these welds \ plates to crack?
Dreams are the blue print for reality.
Good Answers: 62
Re: Carbon Steel Mild Steel cracks.
05/12/2009 10:43 AM
I could give you some coaching on how to make welds that crack based on experience teaching myself to weld , but I got nuthin' on cracking good welds.
05/12/2009 10:48 AM
Please tell me more on how to weld cracks!!!
Location: united states, california san francisco bay area native
05/12/2009 11:03 AM
IMHO: welds can crack due to :
moving the rod to fast in the seam,( staying to long in one spot , bigger hole to fill now )
having the wrong material as your welding rod...
have the surface area being contaminated...
sounds as though the students have learned the art of welding very well...
to induce conditions that facilitate a failure...
as the techniques for a good weld are known.......
could it be that difficult to see where to introduce the " culprit " .?
give the hardest job to the laziest person & they'll find the easiest way to do it
05/12/2009 11:15 AM
We don't really let the students weld. We just teach them various methods on how to detect "cracks". I'm interested in makeing cracks that are fun to find.
05/12/2009 11:26 AM
uhmm... stress cracks..? place the piece in a vise grab the 90 o arm . bend till , bent the other way till..repeat as required?
i dunno knowww
gl..
05/12/2009 11:29 AM
You must be very strong...
05/12/2009 11:35 AM
manpower is never an issue..... ..that's the least of the materials that's in short supply
05/12/2009 12:18 PM
here in the us.. there's a beer ad for a mexican beer.." the most interesting man in the world "..really very funny..
but in the spot..is a line " bulls , flat out , refuse to fight him "
05/12/2009 11:32 AM
in response to your signature...
and luck is the residue of design
Good Answers: 62
05/12/2009 11:15 AM
For instant cracking, pick any method requiring pre-heating, and simply fail to do so.
Or follow this link and fail to follow recommendations:
http://www.treatrade.hr/pdf/DM/weldcracking.pdf
I can do way more bad welding than good - heck, so can your students I imagine.
05/12/2009 11:54 AM
Try welding onto manganese steel without pre- and post-weld stress relief. Martensite rules, OK?
05/12/2009 11:19 PM
This is a dangerous method to try and induce weld cracks, so please use all the personal protection (safety glasses, leather gloves, etc.). After the plate has been welded and it's good and hot, toss it into a container of liquid nitrogen. The shock alone should do the trick.
"The best engineers work smart, not hard. Epiphanies and innovation are the results."
Good Answers: 243
05/12/2009 11:22 PM
If you try welding 1144 resulfurized steel you should get cracks.
Heat 4140 alloy steel to austenitizing temperature then water quench.
we always made our set up bars fro our rototesters by machining very fine grooves. also we could make them various depths.
milo
Canada - Member - New Member
05/13/2009 12:44 AM
Another method:
Weld with wet electrodes. Weld steel with a high carbon content. Hydrogen gnerated during the welding disolves readily in the molten metal but is much less soluable in the cold metal, the pressure generated internally in the steel by the hydrogen gas phase results in cracking of the hard metal.
Chama
Hobbies - CNC - New Member United States - Member - New Member
05/13/2009 7:34 AM
I have done that to students in a welding class to drive home the point that electrodes that hate moisture must be kept dry. Dip them (electrodes not the students) in water for a few minutes then set the on the bench to dry over night. The next day is great.
Good Answers: 97
05/13/2009 3:45 AM
Try welding cast iron to chromoly steel or chromoly to black pipe without CO2 or preheating using #5118
05/13/2009 8:52 AM
Spray (flush) them with water on one side only. If you quench them, there is a chance the plates will cool evenly. As far as when to spray, try different temperatures (delays), as the transformation stress will offset the thermal stress around 1400 F (red hot).
Hobbies - DIY Welding - pipewelder
05/13/2009 3:22 PM
You will not get mild steel to crack by quenching it in water, it does not have enough carbon content. You need to get a higher carbon content steel and do not pre or post weld heat treat and it should crack fine. Dosing rods with water will not usually cause cracks but will however cause plenty of porosity due to the water vapor displacing the protective vapor(smoke) from the flux or shielding gas and letting oxygen in the air contaminate the molten puddle. One way to get mild steel to crack is by welding a circular flush patch continuously in one direction and the stress will cause the adjacent tacks to crack. Another way to do this is to weld one bead on one side of a Tee joint as cold as you can possibly make a decent weld and then turning the machine up and running several beads on the other side. With mild steel the only way I know to cause a crack is by introducing heavy uneven stresses to a weld joint. One other thing you might try is to weld a open butt weld joint while you have vibration. I know that many times I have welded objects in the field when vibration from a motor or some other source the weld will tend to crack.
pipewelder
05/13/2009 8:43 PM
Once again Pipewelder has beat me to the punch line. To get the kinds of cracks you want for training purposes, you need to design a highly restrained joint that will be the weak link in an assembly and then do everything wrong while welding that joint. My best suggestion would be to weld either a T-1 (514, 517) or an HY series steel cold, with cold 11018 electrodes that have been sitting out for a day or two. Let rest for a minimum of 72 hours and Viola!, transverse cracks.
How can you be two places at once when you're actually nowhere at all?
Register to Reply 19 comments
ahuha (5); bwire (1); chama2633 (1); edignan (2); Jerry New Hampshire (1); Milo (1); pipewelder (1); PWSlack (1); Quobaldt (3); Rocket48 (1); The Mechanic (1); titi-the-rabbit (1)
