Previous in Forum: Duct Size and Static Pressure   Next in Forum: Ball Studs and Leveling Devices
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Centrifugal Pumps and Pressurized Seals
05/13/2009 5:17 AM
Assume we have an overhung centrifugal pump having the following details:
- operating fluid is propane;
- operating temperature 40 degree Celsius;
- tandem mechanical seal Plan 52;
- suction pressure 21 bar;
- discharge pressure 28 bar;
- 3000 RPM, driver is an electrical motor 75 Kw;
- flow is 318 cubic meter/hour;
- γ is 0.45;
- buffer fuid is diathermic oil.
While operate this pump in some hours the buffer fluid is lost outside or to the connected flare when is connected to flare the seal pot, due the overpressurizing of seal pot reservoir. The question is why the seal pot become presurised? We assumed that some operating fluid is coming in this seal pot. The plan 52 stated that are allowed from zero to very low process emissions. The second question is what does mean very low process emissions? How much quantity ( i.e. how many milliliters per hour ) ? This very low emissions could have a reaction with buffer fluid and in this way generate that pressure which force the buffer fluid outside from the seal pot?
Thanks a lot to all
Look over to the next challenge
Re: Mechanical Seal Plan 52
05/13/2009 9:16 AM
Simulate a reaction of propane with buffer fluid and see the result.
Good Answers: 21
05/13/2009 9:18 AM
Good ideea but still to ask about what does mean very low emissions.
Thank you
Re: Centrifugal Pumps and Pressurized Seals
05/13/2009 3:51 PM
What they are saying is that if you check the outer seal you will have low emissions. That is because the propane vapor should be going to flare not to the atmosphere. There is no real number of parts per million or anything like that. Your pot pressure will not exceed your flare pressure if properly installed. Make sure the seal you are using is designed for tandem operation. That the pot is installed correctly for convection flow. That the lines to the seal are minimal and vent any air back to the pot. Also the hot return line to the pot must always be below the pots liquid level.
Register to Reply 3 comments
Anonymous Poster (1); user-deleted-1104 (1); venturiano (1)
