Previous in Forum: Centrifugal Pumps and Pressurized Seals   Next in Forum: Direct Writing Technology
Ball Studs and Leveling Devices
05/13/2009 7:01 AM
Hey,
does anyone know how do they insert the ball stud to the pad in LEVELING DEVICES?
Thank you,
Nir
Good Answers: 143
Re: LEVELING DEVICES
05/13/2009 7:38 AM
Yes. In some devices, the pad is split and then fastened together after the ball is inserted. This keeps the ball well-captured, and you can adjust the friction. It is expensive.
In most, the pad socket is slightly larger than the ball, and the edge of the pad is then deformed (essentially rolled) to hold the ball. There is usually not much holding the ball in, but you don't need much. This is fast, easy to automate, and cheap.
You could make one with a shrink fit, I suppose, but that would be both expensive and not as strong.
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Re: Ball Studs and Leveling Devices
05/13/2009 9:05 PM
and sometimes they heat the pad and super cool the ball, insert the ball into the socket and then let them set until the temperature equalizes between them. There is enough contraction and expansion between the two to grasp the ball.
Could be worse, it could be me. :)
05/14/2009 5:15 AM
Thank you very much.
Can you estimate to which temp. do they heat and cold?
Nir
05/14/2009 11:55 PM
I figure, the pad is put in an induction heater to about 250 C, just before things start changing in the metal molecules. The ball -40 C or so, easy to get with dry ice (frozen CO2) or liquid nitrogen. These temperatures are far enough apart to allow for enough expansion and reduction size to allow them, to be mated without too much push and keep together when at the same temperature.
Anonymous Poster (1); mayt2u (2); TVP45 (1)
