Previous in Forum: Transducer or Transmitter ?   Next in Forum: Frequency Inverter is Over Current
Circuit breaker,Contactor, Relay & switch
05/14/2009 7:26 AM
Please elaborate differences between :circuit breaker,Relay,switch,contactor.
Good Answers: 18
Re: Circuit breaker,Contactor, Relay & switch
05/14/2009 9:41 AM
I'm going to assume that you're just curious and not wanting someone to do your homework for you.
A circuit breaker senses current, and breaks contact by bimetal, thermally actuated contacts, electromagnetically actuated contacts, or electronic means, to illustrate a few of the most common (although electronic means is not exactly common).
Relays are, in the most common form, an electric solenoid (electromagnet) which pulls on an armature to which a contact (one or more) is physically connected, and upon enegrgizing the electromagnetic coil, the contacts close, and upon de-energization, the contacts open. Around 45-50 years ago, solid-state relays began to appear on the market, and they perform the same functions as simple electromechanical relays do with semiconductor devices.
Switch is nothing more than a hand-operated set of contacts (one or more). Open in one position and closed in the other.
Contactor is a relay.
05/14/2009 3:38 PM
