Previous in Forum: Free Draining, Slope or No-Pocket   Next in Forum: compress argon from its storage tank vent
Minimum Design Metal Temperature (MDMT)
05/14/2009 1:53 PM
I am an engineer new to this area. We are designing a cooling system with propane (98%), for an environment with a minimum temperature of 16 º C, we have now determined according to the conditions of process that only requires a single step in the process of compression. Currently we are determining the wall thickness of some vessels, to select the material must determine MDMT.
My question is if anyone has any foristas of the document where I can read and review some sample calculations, we would determine it without the help of software?
Pathfinder Tags: mechvcant
Re: Calc MDMT
05/14/2009 2:29 PM
What code are you designing to? ASME, BS, PD, .......
Re: Calc MDMT
05/14/2009 5:36 PM
ASME Code
thanks
Good Answers: 51
Re: Calc MDMT
05/14/2009 5:43 PM
You should really have the code then, but you may find examples in the following book preview from Google:
http://books.google.com/books?id=_8nVW5RMnjYC&pg=PA23&dq=casti+asme+viii#PPA9,M1
A little knowledge is a dangerous thing.
Re: Minimum Design Metal Temperature (MDMT)
05/15/2009 10:16 AM
I am a vessel designer where I work and we fabricate vessels for Natural Gas, Oil, Water, desanders, etc.
I would consider using a SA-516-70 Grade plate rolled to a specific diameter for the shell. The heads can be either pipe caps or formed heads depending on the diam needed.
If the diam is small enough you can sub in SA-106-B grade SMLS Pipe also. It is also good for -20°F to over 100°F
SA-516-70N is great for -55°F to over 300°F. Propane in my line of work is a Sweet Service so very little corrosion allowance is required.
Hope this helps. If you need specific information on grades I can provide the Sect II Part A information for that grade of material.
Stephen
Register to Reply 4 comments
Anonymous Poster (2); pipelinevzla (1); XMech (1)
