Previous in Forum: Minimum Design Metal Temperature (MDMT)   Next in Forum: NUMBER OF WELD PASSES FOR STEAM PIPE?
compress argon from its storage tank vent
05/14/2009 3:12 PM
what type of compressor will be suitable to compress argon from its storage tank vent.
suc pr to comp ( ie from vent): @ 1.6 bar,dis pr reqd @20 bar,flow :50 Nm3/Hr.
Good Answers: 58
Re: compress argon from its storage tank vent
05/14/2009 9:16 PM
You do not give suction temperature?
Argon has a high Specific heat ratio of around 1.67. If suction pressure was say 20 degC you would get about a 380 degC temperature rise across the machine, which would require say a 3 stage reciprocating machine with inter-cooling and possibly after-cooling.
Reply to Forum Thread
