Previous in Forum: Top 100 CR4 Users - Number of Posts and Good Answers   Next in Forum: Meterial for Easy to weld and strength together?
Challenge
05/14/2009 3:51 PM
I am using a software that requires assignment to a com port to recognize the hardware necessary to make it work. I have a RF reciever that is a USB, is it possible to build or is there something available that will enable me to us a USB to DB9 serial adapter cable so the computer will recognize the port and then convert from a DB9 back to a USB so I can plug the reciever into?
Thanks
Good Answers: 140
Re: Challenge
05/14/2009 7:13 PM
Lantronix ( http://www.lantronix.com/) has in the past built devices that allowed for full RS-232C emulation over Ethernet. Which I have used to allow remote Ethernet equipped laptops to talk to serial port equipped PLC modules.
We also used it on PCs with no comm port, the Lantronix device came with a software driver that made the PC think there was a UART based comm port, then redirected everything sent to that particular comm port out to their device instead. Worked slick as could be... the software was oblivious to the difference.
Perhaps they have what you need...
Reply to Forum Thread
You might be interested in: USB Connectors, USB Products, Serial Hubs
