Previous in Forum: Pressure Tanks   Next in Forum: strain gages vs average strain from FEA
Gas Flow Forces
05/15/2009 3:43 PM
We are calculating forces around piping and have some problems with the initial flow development.
Does anyone have experience with the the flows and flow dynamics in a piping system with the initial surge of flow. Our situation is natural gas at 1440 PSIG venting through a two inch full port valve to a vent stack.
I understand what is happening after the flow is developed with a standing shock wave somewhere at end or change in diameter.
What happens during the time between no flow and fully developed flow? I understand that an expansion wave travels upstream to the source and a travelling shock wave travels downstream to the end.
Maybe the question is can we open a 2" valve fast enough to create a shock tube effect?
Is this a way to get supersonic flow for a short time without a converging diverging nozzle? How would it revert back to sonic flow?
Thank you,
Paddler
Good Answers: 183
Re: Gas Flow Forces
05/15/2009 6:41 PM
Most probably not, at least at 1st view. The opening time to generate a shock wave has to be very short. In shock wave generators the opening is obtained in some designs with the burst of a diaphragm. A valve will never have such a short opening time.
Re: Gas Flow Forces
05/15/2009 8:28 PM
Any idea how flow might develop? I suppose there might be a normal shock at the ball valve as it opened, but after it was opened, the shock would have to move to the end of the pipe. How does this happen?
Good Answers: 183
Re: Gas Flow Forces
05/16/2009 6:58 PM
The dp/dt depends on the opening speed, the lower the da/dt (section/time) the lower the amplitude so that you cannot ant more consider it as a "shock wave" but only as a pressure wave. The wave amplitude and speed will depend on the pressure in the volume to which the gas flows.
Register to Reply 3 comments
You might be interested in: Piping Services, Piping Systems
