Greetings from Olympia.
I am looking for a gas water heater, boiler thermacouple tester. If you take a water heater gas valve apart the manufactured tester looks very much like what you have that is inside the valve just under the red button on top of the gas valve.
It looks like a plastic tube with threads at one end and a push button with a spring at the other. The thermacouple screws into the threaded end. Fire is applied to the tip of the thermacouple and when you push in on the button it stays down being held by the millivolts through a coil which evidently has a magnetic field enough to hold the button down for at least 1 minute. Kinda simple and it works. Only place I found was not available anymore.
I am looking for one to test left handed and right handed threaded thermacouples. Or if there is an adapter so I only need one type ie right handed and the adapter. I am looking for about 12 depending on the price.
Thanks I appreciate the help.
Olie.
