Previous in Forum: Rotary Phase Inverter   Next in Forum: Is There Anything Silicon Can't Do?
Relays and Contactors
11/24/2006 5:48 PM
Hi Guys,
Im currently training to become an electrician and i have been messing about with some relays and contactors in our workshop. I am very keen to learn some more about how these can be applied and cleaver things that can be done with them.
I have had a good look on the net but can find anything. Can anyone point me in the direction of some good web pages for this?
Thanks
Steve Taylor
Good Answers: 54
Re: Relays and Contactors Info
11/24/2006 9:26 PM
Hi Steve,
Really, the net has loads of information! I find it a bit strange to hear that you've found problems getting them. Can I assume that you're new to the 'net?
Anyways, I typed "contactor" in Google and got these two. It didn't take me too long though cause these two sites were in the first two pages of the list. I didn't have to go looking through all 1,560,000 sites that Google gave (don't have that much time).
http://www.allaboutcircuits.com/vol_4/chpt_5/2.html
http://en.wikipedia.org/wiki/Contactor
Contactors and relays are not terribly complicated and shouldn't take you more than a day to get the hang of them. Actually, a day's too much at that.
I like your enthusiasm though. I hope you don't lose it. Don't be afraid to ask even if some people give sarcastic or bad answers.
11/26/2006 2:38 PM
Hi
Thanks for your reply. I have been using the net for a long time and it not that i cant find anything. It that i cant find the kinda thing im looking for.
My boss showed me a little trick using two momentary switchs looping back in to the relay to be used as a start and stop button.
This is the kinda thing that im looking for. Maybe some simple circits that i can try out to try to get more a feel to what can be achived using these.
Steve
Good Answers: 53
11/27/2006 5:27 AM
Steeve the switch you are talking about is known as latch switch. This gives luxury of controlling large power with small switch. Also in case of power failure you will have to reset your power. So it works like a motor starter.
To learn about a relay or contactor you need to have some basic info about them.
1 what are critical test parameters,
2 Why they are critical
Here are few critical parameters
1 contact resistance
2 contact sizes.
3 contact ratings. Volts and current
4 type of contact (material) Ag, AgNi, AgCdO, Cu, etc.
5 hysterics
6 trip voltage.
7 reset voltage.
8 coil resistance
9 input current of coil.
10 rated coil voltage.
11 insulation resistance
12 Dielectric strength
13 Burn out protection
14 contact time constant
15 contact life in Cycles.
16 EMI
And there can be many more
Now if this helps you pls reply, then I shell give you info why they are important.
11/27/2006 6:27 AM
Actually, Rakesh, he's looking for sample circuits that he can use. The motor starter was just an example. Right now, he's more interested in applications, not the details of how they work or how to select or how to design.
I can think of a few samples myself, like a speed answering contest where each contestant has a button. When a contestant presses his button, his light goes on and the other contestant's buttons are disabled. The contest host will then know who pressed first.
I think this is the kind of information he's interested in.
11/28/2006 12:34 PM
Yes thats exactly what im looking for. Simple stuff that i can make and see how it works.
Like the speed answering contest
How would that be done?
Thanks
Steve
Good Answers: 54
11/30/2006 2:13 AM
Seems our other guest can't deliver.
Here's something I had to dig deep into my old files for. I don't know if you can save and enlarge it from here. CR4 shrunk it when I pasted it.
Anyways, this is a three-contestant speed answering circuit using all relays. If you want to have more contestants, I'd suggest you go digital.
When a contestant pushes his button, his relay disables the other two buttons and lights up his own lamp. The host or contest chairman then pushes "reset" when he's ready to ask another question.
Anonymous Poster (3); rakesh_semwal (1); Vulcan (2)
You might be interested in: Electromechanical Relays, Aerospace Contactors
