Previous in Forum: Real Power Value (KW) and Apparent Power Value (KVA)   Next in Forum: Appliance Cables
Why Use 3.5C Cables?
05/17/2009 2:09 PM
CAn anybody pls tell me where n when n why we are using 3.5c and 4c cables........?is 4c used in unbalanced loads?
"Know something about everything and everything about something"
Australia - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Electromechanical Engineering - New Member
Re: 3.5c and 4c cables
05/18/2009 4:53 AM
You would use 3.5 cables to supply a panel load that is predominately a full three phase, and balanced. A good example would be a motor control centre that will have a low single phase load. I would consider using a 4 core to light and power distribution boards instead of 3.5 because there is more of a possiblity that there would be a substatial single phase load which can become unbalanced easier.
tooz
