I need some products to be manufactured in FRP So that i can try to reduce its weight keeping strength and safety as same as that of steel or even higher.
Vacuum bagging of FRP will give minimum resin weight with maximum strength. Kevlar &/or carbon fibre has better weight to strength than glass fibre. Why FRP? Foamed aluminium has corrosion resistance, high strength, and low weight
