Previous in Forum: Rarefaction of a Gas   Next in Forum: Chlorine Cylinder Problem
19 comments
How to Insulate and Ship Expensive Bottles of Wine
05/19/2009 9:26 AM
Hello Everyone,
I am new to this and not a techie or very knowledgeable in terms of engineering, so thanks for your patience.
My question:
I am wanting to get a hold of some really good insulator material such as Seagel or Aerogel, in order to create sleeves for shipping some expensive wine bottles to a dear friend of mine in Europe. The goal being that the bottles should be so well insulated that the temperature of the wine bottles does not change, as that changes the quality of the wine, as you know.
So...anyone out there has some good ideas for me to make this happen?
It does not HAVE to be Seagel or Aerogel (they are the only ones I have heard of that are great insulators), but can be some other type of material that does the job.
I would like to contact someone and buy some rolls (if that is possible) and then experiment with creating the sleeves myself.
Thanks a lot in advance for your help, I really appreciate it.
Alex
Good Answers: 62
Re: How to Insulate and Ship Expensive Bottles of Wine
05/19/2009 10:10 AM
I feel your pain.
But thermodynamics is/are thermodynamics.
Given a temperature difference and a boundary - eventually things WILL equalize, the greater the difference, the faster it happens (well, OK - the faster SOME temperature change will occur, not necessarily the faster they will equalize).
So the first thing (it would seem) would be define what the time span is, what the threats are, and how long we can hold them off practically.
Unless they are carrying pets, airlines typically do not heat the cargo bay. It is cold up there. You say shipping from Europe, broad range of temps but can be quite hot during cargo operations during the day. So first you want to protect from say 100F on the ramp, approaching 0F inflight, back to 100F on the ground in US - and sitting in air conditioned comfort.
I'm also told wine doesn't fly well, is that atmosphere or temperature?
So we have a second profile ambient pressure, to ~20,000ft, and back to ambient.
And the period of flight could be ~12 hours?
Tough challenge.
05/19/2009 11:58 AM
EDignan,
Thanks for your prompt reply. Yes, you are right about the temperature changes on a flight...especially about it getting real cold "up there", but also the change from ground temperature to "air up there" temperature. And there is the pressure...as you mention...but...I wonder if the cargo area on an airplane is "equalled" out in terms of airpressure just like for the passengers??? If yet, pressure would not, it seems, play any significant role for the wine bottles..."merely" the temp. change. Which...I was hoping...some type of Aero/Seagel could help with.
Other scenario:
Only doing ground-shipping of wine bottles..lets say..only in the U.S...between states...pressure would not be an issue as the bottles would all be on trucks...and the temperature would still be an issue....in some ways.....
The issue is: to be able to keep the bottles at the same temperature..AS BEST is possible...and...to be honest...I have not done enough research on HOW bottles are being shipped as it is...today...via the ground-service...and how people account for or deal with the temperature change....any ideas here on that one?
I am just interested in SOME type of insulating material that I can buy, which will prevent heat AND cold to get to the bottles....but...as I mentioned above...maybe there are some efficient ways today that I am not aware of.
But.then why would a good friend of mine then...who is in the wine business...tell me about the need for such a material....at least he believes it would be beneficial????
Any info on where to get some type of heat insulating material...would be great.
(someone told me within the last day about a good ceramic based insulator called...refractory composites...by Zircar...but dont know what that is)...Perhaps that is an area I need to look into for my need???
Thanks again,
Alex
Good Answers: 243
05/19/2009 3:59 PM
Well I'm no wine expert, but Ive had wine sent to ohio via UPs. it was in a six bottle styrofoam package, inside a cardboard box. If you put that in a box filled with styrofoam peanuts, and then wrapped that box with foil and then put it in another sytrofoam lined box you would have done about all that you can.
If in the summer, you could put an non water ice pack in one of the outer wraps to help moderate the temp before it gets to your inner sanctum sanctorum.
Good luck.
milo
Location: united states, california san francisco bay area native
05/20/2009 2:52 AM
stuck between having the wine in the fwd pit, heated,.. or aft pit.. unless the pressurization sys fails, cargo pits are part of the a/c pressurization sys..so the psid would never have the cabin psi above 10k feet..the wine need only worry over temp changes..i think
38k feet .going this way 38k going that 39k... ambient temp : - 40 c..ballpark..
but the good news , if psi sys failed in flight , more than likely descend to 10k feet..
on many flights, the cargo door seals still had ice on them , after descending from flight cruise .. to enter into the air traffic zone for that city.. till touch down taxi into the gate...
2 cents
give the hardest job to the laziest person & they'll find the easiest way to do it
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
05/19/2009 12:30 PM
You could try an international wine shipping service. I found this one quickly on google:
http://www.winebyairintl.com/
I'm sure there are others.
Remember, there are laws to deal with too.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 16
05/19/2009 8:33 PM
Roll 'em up in 4-5 layers (1 1/2") bubble wrap, tape the ends. put an inch or so of popcorn, (salt op. ,no butter) in the bottom of a heavy cardboard box. Fill with popcorn around and in between the bottles. Compress to close. Label: 'Fragile, Liquid in Glass', 'Adult signature required', 'This side up' (with arrows). Check with UPS or Fed X, to see if that's all you need to do. Packaging is biodegradable, or you can eat the popcorn.
De gustibus non est dispudandum.
05/20/2009 12:41 PM
They now sell the packaging popcorn as food. My wife fell for it and still likes it! At Costco it is called "Pirates' Booty" and at Trader Joes it is sold by "Buccaneer Joes" and has a sour cream and onion flavoring salt. But they are packing peanuts made with corn starch and added flavoring.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
05/19/2009 8:56 PM
Vaccines and similar products are shipped in temperature controlled containers. Bit like a mini 40' refrigerated container. Something like this may be suitable, but I suggest you ask the question to DHL, UPS or Fedex to see what they say or can offer. Maybe sea freight is a more confident option.
Interested to know the outcome solution.
05/19/2009 10:57 PM
For "run of the mill" quaffing wines, no such precautions are necessary. Heck, they serve wine on most flights with no problem.
For the specialty wines that you are talking of, I'd especially consider temperature controlled shipping containers whether by sea or by air and I'd also include handling (shock and "this side up") monitoring labels and detectors.
If the wine is that precious, then it definately needs active environmental controls rather than passive insulation and bubble wrap. (Of course you need to provide protection against breakage.)
There's already one good link earlier in the notes and the international freight companies know their stuff. I've even seen live seafood transported from Asia to Australia, custome cleared and everything. The secret there was the intermediate packaging agent was a specialist.
alternatively, get your friend a return ticket and they can drink it with you and share the good times.
05/19/2009 11:04 PM
Hi Alex,
I've shipped wine Australia to Europe (and back again) many times. Wines that I have been very familiar with - and haven't seen such problems (other than is to be expected with the % failure rate of corks or other closures).
I've worked with winemakers, who've used the line "It hasn't travelled well, etc" but I believe this to be an excuse for them presenting a poor quality wine, trying to pass it off as good quality.
Best idea is not to reinvent the wheel, and just use styrofoam. it keeps the wines in good shape (both the quality and physically), and it is recognised by courier type people as a normal Wine package (I can imagine them being suspicious of your package because of the unusual container, possibly confiscating, or opening, possibly causing damaging etc ).
Here's an alternative idea, just drink the wines. And send your friend a cheque for the money you would've spent on making the perfect shipping container.
But seriously in my experiance, ship it as quickly as possible (express). Try to minmise temperature fluctuations. Styrofoam bottle moulds inside a cardboard box work well. Even a little bubble wrap, would help.
Damage can occur if sent by snail mail (where the bottles are left sit in a hot place for an extended period of time). Send by express.
Don't worry about pressure fluctuations, if the bottle leaks, or has air ingress, then the seal is faulty, and the wine would be poor in any case (no matter what country it was opened).
The beauty of wine is the chance of getting a good bottle.
Hope this helps.
Cheers,
AJ
05/19/2009 11:28 PM
The best way to ship wine is to carefully pour it into a conatiner made from human protoplasm and maintain it at 98.6 degrees F until it is processed into another product altogether. The second product can then be piped into a local refinery and returned to the nearest river.
Good Answers: 68
05/20/2009 1:21 AM
Hello acarend,
I will search for the gel stuff shortly. But have you thought of expanded polystyrene as a insulated package wrapper? It also absorbs any knocks. You could may be use what you have in mind, combined with this product to get your wine safely to your friend?
Have you thought about asking professional wine shippers how they send that extra special type of wine like Port etc?
Just a thought................
bb
Good Answers: 68
05/20/2009 1:27 AM
Hi acarend,
I forgot to welcome you......I hope you stay and become part of this site. There is some great and clever people here. And there is always a question waiting for you to answer it. Just double check your answers first before posting. I have answered a couple of times with incorrect answers and wish I had taken more time.
They are a friendly bunch, so jump in and enjoy!
http://www.google.com/search?client=safari&rls=en-us&q=Aerogel&ie=UTF-8&oe=UTF-8
bb
Good Answers: 68
05/20/2009 1:30 AM
Hi acarend,
http://www.google.com/search?client=safari&rls=en-us&q=Seagel&ie=UTF-8&oe=UTF-8
bb
05/20/2009 8:19 AM
You can buy double wall vacuum flask and place your wine bottle inside and then insulate this with R38 fiber insulation and then final rap of liquid polymer bubble type insulation.
This will keep temperature constant what is inside the flask for a week with not more than 0.005C change if the total out side temperature delta is less than 50C from start to end distination
Masyood
Good Answers: 25
05/20/2009 8:29 AM
Google "phase change material". Standard polystyrene foam wine packs will protect from impact damage. In order to preserve the proper temperature phase change materials are used in critical shipments of medical supplies and can be reused. There are many temperature ranges to chose from and there should be one to fit your wine application.
Goodness has nothing to do with it.
05/20/2009 7:04 PM
I've shipped wine overseas in Styrofoam successfully. The packing was solid and form-fitted especially for wine bottles. It was Styrofoam with wine bottle indentations in it. I purchased the Styrofoam packing from the wine seller. It provided for very good physical protection. Although Styrofoam is a good insulator, I'm not sure about long term temperature problems. Because of security concerns, I would not try to pack the wine in carry-on luggage.
Don
The only people who don't make mistakes are those who don't try.
05/21/2009 6:03 AM
The main problem is probably to try and keep the wine at average temp and not allow it to get to extremes - especially high temp.
Standard polystyrene is the best bet.
Over short periods, wine is not very sensitive to low temps, provided it doesn't freeze.
High temps cause some degradation, but takes time to do so. You have some tolerance. If you can hold it to average temp on the ground, there shouldn't be a problem there.
In the air, the act of pressurizing the cargo hold keeps the temp about the same as standard atmosphere at 10,000'. The hold obviously stays above freezing, otherwise you would notice the coldness of your luggage when you collect it after a flight. This shouldn't be a problem over a 12 hour flight.
Good Answers: 68
05/23/2009 8:58 AM
Hello acarend,
I would choose the polystyrene which you should find in either bottle shapped cases or a box of a dozen spaced in moulded polystyrene. Ask the shipper and airline company if you can seal the pack round the edge with the same type of sealer used on baths. If not you could always put some kind of foam rubber round the edge and tie the top on with tape and or string. This will keep the contents at atmospheric temperature I would stick to tape and then there is less likelihood to them grabbing the string and throwing it.
If it really in extra special, then do the same, but send it via ground shipping. The temp will stay more or less the same and no pressure to worry about. If it is extra extra special, then take it yourself!
Bear in mind that there is always the chance of an airline opening any box or container. They have to sometimes to find what the box contains. Taking it yourself, you can ask if you can transport it in the passenger carrying part of the plane and so keep your eye on it.
Take care and please let us know what you do and how OK?
bb
Register to Reply 19 comments
acarendi (1); ahuha (1); ajwinemaker (1); Anonymous Poster (1); AussieBob (1); babybear (4); beriberi (1); Bricktop (1); Don in LA (1); edignan (1); Just an Engineer (1); Masyood (1); Milo (1); sceptic (1); Thor (1); Tippycanoe (1)
You might be interested in: Electrical Insulators, Web Cleaners, Water Coolers
