Previous in Forum: Problems Raising pH to an Acceptable Level   Next in Forum: How to Insulate and Ship Expensive Bottles of Wine
Rarefaction of a Gas
05/19/2009 6:25 AM
One tank, full insulated, with volume of one cubic meter and with ammonia at 473º K and 20 bar. The density is 9Kg/m3. We reduce the density opening a valve, maintaining the volume of the tank constant. The pressure will drop. We stop emptying the tank when we reach 1 bar. What will happen with the temperature of the remaining ammonia in the vessel as we empty the tank? It will remain at 473ºK or will drop?
The attached table is from NSTI. Ammonia - Isothermal Data for T = 473.00 K
"Simplicity is the ultimate sophistication" Leonardo da Vinci
Re: Rarefaction of a gas
05/19/2009 6:56 AM
It is an adiabatic expansion, so the temperature will drop.
Re: Rarefaction of a Gas
05/20/2009 3:33 PM
Any gas, when allowed to expand freely (ie. into an unconstrained space) will cool the remaining gas in the tank.
Pressure times volume equals (gas constant) times Temperature times Moles of Gas, so if you drop the pressure, keep the volume the same, all else stays the same except temperature must go down linearly with pressure.
05/21/2009 6:21 AM
I think 473K is above the critical point of NH3, so as the pressure drops from 20bar, the temp will fall although it probably won't follow the simple adiabatic expansion formula being initially too close to critical temp (from memory about 400K).
If you have good insulation, by the time you reach 1 bar, temp will have dropped significantly. It is a standard refrigerant, so a set of refrigerant tables or TS diagram will tell you what the temp will be by that time.
The same tables will tell you the temp when you have dropped it to a low pressure from your 1 bar left in the tank.
If you are simply trying to empty the tank for maintenance, you could try using dry nitrogen to purge the gas out once you get to atmospheric pressure. Compressing and cooling the resultant mixture later will allow you to reclaim the NH3 when it liquefies.
Register to Reply 3 comments
Anonymous Poster (1); PWSlack (1); sceptic (1)
