Previous in Forum: electrical eng   Next in Forum: Motors - Frequency of Lubrication
220 VAC voltage reducer
05/19/2009 2:44 PM
I have a point-of-use electric water heater that is too hot for kitchen use. The single handle faucet will not allow enough cold water for proper temp. I think I need a means of reducing the voltage so that the water does not get too hot. Any ideas?
Re: 220 VAC voltage reducer
05/19/2009 3:05 PM
What's the maximum current draw of the water heater?
05/19/2009 3:29 PM
The common method of adjusting water heater temperature is to adjust the water heater's thermostat (the device that regulates the water temperature preventing the water heater vessel turning into a bomb and exploding). Does your water heater have a thermostat, either mechanical bi-metal or electronic (I would be surprised if it doesn't) that you can adjust or replace?
05/20/2009 3:12 AM
Is this a symptom of there not being enough flow through the water heater? If so, then what is affecting it -
  • a valve elsewhere partially closed?
  • "furring up" of the pipework?
  • "furring up" inside the water heater element chamber?
  • insufficient head on the incoming supply system?
  • etc.
Anonymous Poster (1); jack of all trades (1); PWSlack (1)
