Previous in Forum: Liquid Jet Ejector Nozzle Design   Next in Forum: Calculating the Weight of Steel Angles and Channels
11 comments
Lubrication System Design
05/21/2009 8:34 AM
I need to design an oil lubrication system having several (10) machines drawing from a pressurised supply with gravity return to a continuously, kindney-loop filtered storage vessel.
Question one. I need to calculate how much oil could be required at any given time. Help!
Question two. How do I determine what size tank I need to store the system reserve? Limited space available, would like 500 gallon.
Thank you.
Pathfinder Tags: Oil system
Good Answers: 101
Re: Lubrication System Design
05/21/2009 11:44 AM
Where are you located?
05/21/2009 11:59 AM
Owensboro, Kentucky.
Good Answers: 101
05/21/2009 12:09 PM
I'm not sure who I'm supposed to direct you to in Kentucky...
Call up our Lube Specialist, and see what he says. We typically give our engineering away for free in this industry. (its sad, I know)
(hydraulics, Pneumatics, motion control, Lubrication)
503-250-4904
His name is Kevin
Tell him Russ sent you.
If you cant get through, try the main line
503-667-9222
05/21/2009 1:57 PM
Thank you very much Russ.
Sean Boyce
India - Member - New Member
05/22/2009 2:07 PM
What ype of machines are these ? What is the loading condition / will it generate too much heating / if so then you need to keep Tank - Oil Sum size 3 times the normal Oil requirement.
As regards to the oil requirment at any point of time, you must calculate the quantity of Oil required by each machine multiplied by the numbar of machines under operation at that particularl moment and count the highest of all this.
Born Enquisitor !!!!
05/26/2009 8:32 AM
They are wire drawing machines. Basically a oil flood or low pressure shower design. Obviously the flood systems just fill a drawing chamber where stepped capstans are used to pull wire thru a cold drawing operation using carbide, composite or natural diamond dies. The wire reduction % is the fundamental controlling factor for everything else. Capstan size determines the reduction of the machine. Anyway, the only heat is generated by the circulation of the oil, the point of draw at the dies and slip on the capstans. We have several machines with tanks of only 20 to 50 gallons. We need to keep the oil below 150° F, per supplier operating instructions.
Is this something that is a product of line size and fluid pressure? Each machine has a pump and supply lines of various size. I have no way to measure flow, therefore I am sure that it can calculated. The system I need is a single supply pump (with back-up) pressurizing a line the machines tap into via solenoid valve when required. They do not operate at the same time, all the time, but may sometimes. I need to know how to calculate maximum system pressure requirement, I think.
03/27/2012 10:47 PM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
05/22/2009 6:11 PM
What are you lubricating? Do you have compressed air? OIL SMOKE® might be the answer. Tom
05/26/2009 8:36 AM
I am lubricating wire that is being drawn as well as the capstans that are pulling the wire through the dies. The systems are either a flooded or low pressure shower design. I could not find OIL SMOKE to research, too much to filter on the web, so I do not know what that is.
Good Answers: 103
05/26/2009 8:41 AM
I think he meant oil mist lubrication. This is commonly done on machines by spraying with atomised oil.
Just a link for you, however a lot of material exist on web.
http://www.machinerylubrication.com/article_detail.asp?articleid=799
05/26/2009 8:52 AM
Thank you, I checked the link, it is more like water pouring out of a drinking fountain.
Register to Reply 11 comments
6SigmaBB (5); RVZ717 (2); sb (1); Tom Kreher (1); tuchunbo (1); zankruti (1)
