Previous in Forum: Lubrication System Design   Next in Forum: Flow Reduction End Caps / Orifices
11 comments
Calculating the Weight of Steel Angles and Channels
05/21/2009 9:28 AM
if anyone give me the calculation of steel angle, i have tried with (L X W X H) X density but not found exact result.
Re: exact weight calculation of steel angles & channels
05/21/2009 9:34 AM
do you really need to calculate?
How about using one of the weight charts provided, for example:
http://www.jimssupply.com/angle.htm
Because it would be difficult to get really accurate by calculating due to filleted/sloped edges - they are not all simply straight/flat edges.
Good Answers: 53
05/21/2009 9:35 AM
What is the width and height you have taken?
What are unit, can you put you sample example?
Good Answers: 101
Re: Calculating the Weight of Steel Angles and Channels
05/21/2009 11:38 AM
Grap yourself a good rescource such as a Ryerson Tull book. Then look up your material... It will have a "per foot" weight.. multiply your total length in feet with the weight per foot of desired material.
order yours today!
http://www.ryerson.com/corporate/stocklistbook.asp
or use the online version!
http://www.ryerson.com/stocklist/StocklistServlet?COM=GetTable&ID=910
06/25/2009 9:15 PM
Thanks.It is very helpful for the estimations.
05/21/2009 7:09 PM
Bear in mind that you're dealing with an analog quantity here. There is no exact result that can be measured - you'll have to put a tolerance on it.
Variables to consider:
How accurately can you measure L, W & H ?
How consistent are the W & H along the L axis?
Does the value you're using for density correspond exactly to the alloy you have?
Are there any fillets at the angles between the webs? Are all the edges sharp?
Is your weighing machine calibrated?
05/22/2009 12:35 AM
Hi...
If you are in India use the standard SP-6 published by Bureau of Indian standards for rolled sections. Officially they have fixed density of steel as 7.85 gms/cm2.
Anil Tiwari
05/24/2009 2:45 AM
Sorry for the interruption.Hope it is gms/cm3
Good Answers: 25
05/22/2009 8:32 AM
Please visit this link http://calculatoredge.com/ it will give you all information.
Suresh Sharma.
05/22/2009 8:38 AM
Some other places to look, if they are available to you:
ASTM specification A6, the appendix will have weights listed.
The first section of any edition of an AISC Manual of Steel Construction.
Or, try this equation in place of the one in your original post, which won't account for the fillets and such as mentioned by another reply above:
(L + W) x H x density
where:
L, W are lengths of the angle legs
H is the thickness of the angle legs
05/24/2009 12:53 AM
There is no standared formula for calculating weight of structural member for that you have to see standared table.If you wants table please send your mail id. i will send you tables.
06/25/2009 12:07 PM
I want to get weights of M.S and GI steel angles. pl send table of weights
awaiting your reply
thanking you
bedekar_sj@yahoo.co.in
Register to Reply 11 comments
Anonymous Poster (4); JohnDG (1); pokalasrao (2); rakesh_semwal (1); RVZ717 (1); spak15 (1); suresh sharma (1)
