Previous in Forum: Ductile to Brittle Transition Temperature (DBTT)   Next in Forum: Compressed Air Usage
Carbon Fiber vs. Fiberglass Resins
05/21/2009 6:25 PM
looking for basic info on carbon fiber verses fiber glass resins. why is carbon fiber stronger ?
Re: carbon fiber facts
05/21/2009 7:04 PM
Carbon fiber is stronger because the carbon is stronger than glass fiber.
Neither of these are resins. The liquid used to bind the fibers is the "resin".
GENERALLY, polyester resin is used with glass and epoxy is used with carbon.
Some phenolic resins have been used, too.
Check out Wikipedia.Type in "carbon fiber"
05/21/2009 9:39 PM
thanks for the info desert man, too hot for me
Good Answers: 16
05/22/2009 12:39 AM
Carbon fiber is stronger in tension, much less so in compression. Some FRP cloth is made with both for this reason. GENERALLY, polyester and vinylester are cheaper, though epoxy is superior to both. CF is also available in parallel single strands known as 'tows', and can be laid precisely to accommodate stresses, where FG only comes as a chopped strand or cloth, which wastes weight in getting proper strand orientation.
Just my 2 cents worth.
De gustibus non est dispudandum.
05/22/2009 7:48 AM
good answer, thanks for the info, poppabearjules !
Register to Reply 4 comments
lyn (1); poppabearjules (2); Tippycanoe (1)
