Previous in Forum: Tank Explosion Video   Next in Forum: Mini Forge for Medieval-Style Arrowheads
Newtonian Fluids and Shear Stress
05/22/2009 4:50 AM
Could anyone pls suggest me some examples of newtonian & non newtonian fluids. this seems foolish question but which type of fluid is petroleum jelly
what parameters are required to calculate the shear stress for same
Re: examples of newtonian fluids & non newtonian
05/22/2009 5:15 AM
<...some examples of....non newtonian fluids...>
  • Tomato ketchup
  • Grease
  • Petroleum jelly
  • custard, or "crème Anglaise"
  • hair shampoo
  • shower gel
<...which type of fluid is petroleum jelly....>
It's a rheopectic pseudoplastic.
<...what parameters are required to calculate the shear stress for same...>
It depends upon the shear rate, as a graph of stress versus rate-of-shear gives a line that does not pass through the origin; petroleum jelly stays put once it is stationary.
All viscosities are highly dependent on temperature.
05/22/2009 5:15 AM
Mix up some cornfour and water into a thickish paste, if you stir s-l-o-w-l-y it flows.
If you try to stir it quickly it will crack!
Obviously you don't make gravy.
05/22/2009 5:20 AM
Ahah! A "dilatant".
05/22/2009 8:26 AM
Thanx for great reply.
how can we calculate the pressure drop in line or line diameter for non newtonian fluids
what are the main factors which decide this or can u tell some numerical formula for same
05/25/2009 12:52 AM
is nobody able to tell something about same? actually we have to install lobe pump to transfer sauce from process vessel to heat exchanger.
sauce density 1.12 to 2.2g/cm3
viscosity 2000 to 4000 cP
specific heat 3.5 to 3.8 kj/kgdeg celcius
frnds, if u can help to tell how can i size the pipe & pump for same
05/27/2009 7:23 AM
<....calculate the pressure drop in line or line diameter for non newtonian fluids...>
  • The Weisbach-Darcy equation has general application to all fluids in all pipes of cylindrical cross-section.
  • There are simplified forms of it, and even look-up charts for simple, commonly-encountered fluids like steam and water.
  • If no calculation is available or applicable, how about a small-scale trial rig, then scale-up from it?
Register to Reply 6 comments
megha (2); PWSlack (3); user-deleted-1105 (1)
