Previous in Forum: WHAT IS HEAT PUMP   Next in Forum: how to become a certified boiler engineer in U.S.,U.K.,CANADA
India - Member - Electrical Engineering Fields - Power Engineering - Electrical Engineering Fields - Electrical Engineering - Electrical Engineering Fields - Electromechanical Engineering - Electrical Engineering Fields - Energy Engineering - Electrical
HRSG Feed Water Pump
05/24/2009 7:47 AM
Presently, we are using Gate Valve in Feed Water Pump of HRSG. Working Pressure of HRSG is 10 KG/CM2.
Now, Can i change the Gate Valve with Globe Valve of This Feed Water Pump Line,
Thanks,
Sandeep seth
Good Answers: 19
Re: HRSG Feed Water Pump
05/24/2009 11:00 AM
Yes.
05/25/2009 1:04 AM
yes you can how ever its advised to cross check and match pressure drop with gate valve and select and match with globe valve.
crm
05/25/2009 12:30 PM
Yes........if the valve is on the discharge side of the pump and you wish to regulate flow.......it is ideal...........if you do not wish to regulate flow, don't bother, you are better off leaving it as a gate valve (you achieve unrestricted flow).......if I remember correctly, the resistance created by a globe valve is equivalent to a length of 100' of straight pipe.
I am assuming that the valve is on the discharge side of the pump.
Just as a matter of interest, do not use a gate valve to regulate flow, they are designed to be isolating valves only.
05/26/2009 12:45 PM
I hope defintely you will have a standby pump for the Feed water application.If one pumptrips other has to start and makeup for the water. Hence normally we will not throttle the valve and keep full open.( full closed for isolation). hence operation point of view Globe valve is not recommended. If gate valve is not available, use Globe valve with tag ( KEEP FULL OPEN OR FULL CLOSE) for emergency.Hope the standby pump has AUTO START provision.
Take care of the physical dimensions & pressure drop values.
If physical dimensions are O.K, pressure drop will not be problem as design margin will be present (practical sense)
Engineering Fields - Piping Design Engineering - New Member Need help
05/27/2009 12:26 AM
Gate Valve should be used as On or OFF Valve i . e. Fully open or fully close
But the Globe valve can be used in partial and controling the flow
Anonymous Poster (1); bobosboda (1); ducon (1); MOBI (1); murali (1)
